GlennLever
Feb 20, 2014Explorer
Handbasket wrote:
Best start by saying that I've never owned a diesel, but I did work on them in the USN long ago. Here's my interpretation:
Parts # 6 are starting aids, which to me says they're 'choke' injectors. They're akin to the choke on an old carbed gas engine, used to give a richer mixture when starting. Part # 2 is a solenoid (operated) valve, probably energized on cold start and allowing fuel to flow to #6.
At a total guess, it's a generic solenoid valve, with several uses. The second terminal may be to allow for a ground wire when needed. Yours may not need a ground wire, since it may ground thru the mount or the metal line to the 'start aids'.
Check for continuity & resistance with a volt-ohm meter, measuring from the wired terminal to both the body of the solenoid & to unwired terminal. If I'm right, there'll be almost no resistance between the unwired terminal & the body, but there will be measurable resistance between the body & the wired terminal.
Good luck, both with it, and with following my gibberish... ;)
Jim, "The old expert, often wrong but never in doubt."
Your suggestion to check to see if it is grounded through the boby is a good one, thanks, will do, will also check to see if the wire that is connected goes hot when cranked outside in the cold.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
