GlennLever
Feb 21, 2014Explorer
I received a call from from Cummins today.
It is a solenoid/valve. The wire is a 12volt supply that should only be hot when the wait to crank light is on on the dash. It is part of the intake heat system. There is not ground wire, it is grounded through the valve body.
The one tab that appears to be clean and should have had a wire connected to it should be folded over, and be flat against the valve body. When this has been done I suspect we will find that the other side, the side current not showing, will show the signs of passing time.
So... all questions have been answered at this point. Thanks for all your help.
I did receive a finial e-mail.
Hi Glenn,
I heard you spoke with Mike. Was he able to answer all your questions about the part?
Mark
Customer Care Representative
If we have misunderstood the information in your communication or you have additional questions please feel free to respond to our support staff by e-mailing powermaster@cummins.com or call Monday through Friday, 7 a.m. to 7 p.m. ET at 1-800-DIESELS (1-800-343-7357). If you are located outside of North America, you can reach us at 812-377-3000.
For authorized service center locations please visit:
http://www.cummins.com/cmi/index.jsp?siteId=1&langId=1033&newsInfo=true
Cummins.com
Everytime.cummins.com
Hi Glenn,
Mark
Cummins.com
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
