odenwell
Nov 22, 2019Explorer
Ed_Gee wrote:
1) the shunt is the sensor that measures all current into and out of the battery. It should be installed in the negative battery cable going to chassis ground. It does not need to be readily accessible. The best quality battery monitors do NOT use bluetooth....the sensor connects to the display monitor by wire cable.
2) a battery monitor will work with any charge controller.
3)no comment....I prefer hard wired display - no bluetooth.
5) shunt type sensors are extremely accurate .....Not sure how accurate Hall sensor types are in comparison.
Bluetooth is bad? That's a bold assertion. My Victron with Bluetooth works great.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
