NinerBikes
May 21, 2014Explorer
MEXICOWANDERER wrote:
Pianotuna, yes, they can be paralleled if the positives, every positive from every power supply is fed through a rectifier. it's very own.
I chose SHOTTKY look on eBay and make sure the rectifier is rated to take 50 amperes.
But as NinerBikes pointed out - beware of inrush current. Four of these units will tax a 20-amp AC feeder line upon startup. A 30-ampere feeder would be better, or you can make your knees wobble and price a SOFT START module to feed incoming AC voltage.
staggered delay on start AC timer modules (3) would also negate the inrush issue.
Two of these paralleled, will tax a 15 amp AC feeder. Especially if your voltage drops below 120V on start up... Seriously, NO BS. I don't know electronic circuitry well, but staggering, as Mex suggests, is better than doing a big draw, all at once. I can assure you that two of these 30 amp units, turned on at once, paralleled, will stop an Eu2000i with it's 1600 watts 2000 max watts, cold.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
