MEXICOWANDERER
May 21, 2014Explorer
The stuff is "on the way". The issue with this critter is that absolutely everything is adjustable. Lesee the new word is "Tweakable"
Quiescent current draw will be in the microampere range. The gauges and fans only work when the power supplies are supplying. Don't know the "fitability" of a 3 second delay timer, so one 50 amp switch stays off when starting up.
Mexican hotel patrons get cranky when everything goes dark and that ummmm-baby destructive distillates of PVC wire insulation, aroma fills the corridors.
Speaking of which, any switched charger, power supply, or perverter, oops I mean converter operation with generator could answer the following question
PERFORMANCE VERSUS VOLTAGE VERSUS FREQUENCY incoming line energy question.
When does your device performance start to degrade? Maximum potential sag when voltage drops. At what voltage? At what frequency? I am planning to DRACULA hotel room receptacles and forewarned is forearmed.
GRACIAS
GRACIAS
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Mar 31, 2026
