westend
May 22, 2014Explorer
BFL13 wrote:He is using a buck and a boost transformer with regulation circuits. The Ammo Can differs from a conventional charger because the voltage and amperage can be set at a particular level and it holds that setting. He has three settings if I understand the design correctly.
Does this gizmo Mex is building not have the amps tapering? How can that happen?
Maybe the Ammo Can II will have an autoformer built in to control voltage. :B
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
