RVTech1225's avatar
RVTech1225
(Tiffin) Upgrading Inverter from Xantrex RV3012GS to SW 3012
Hey guys and gals,
I'm upgrading an inverter and as it's an older coach it has the 5 Pin white plug for generator controls to the inverter, however the new inverter has a 20 pin white plug I need to wire into. The labels for each wire from the old inverter to the new one are a bit different. As I don't want to wire this up backwards, can anyone tell me which one goes to which?
Labels on old plug:
Gen Start 2 (yellow)
Gen stop 2 (yellow)
Thermostat + (green)
Gen start 1 (black)
Gen run (brown)
Gen stop (blue)
The new harness' diagram is labeled and colored different, any help is appreciated, thanks!
  • Some depends on the genset, but I would start with :
    Old gen start 2 and gen stop 2 (both yellow) to new #16 and #18 - note both should be ground, so it shouldn't matter which is which, and IIRC, I hook all of those together *and* to new #13, which is ground.
    Old Thermostat + to new #1 - Thermostat 1 input.
    Old Gen start 1 (black) to new #17 - gen start, normally open
    Old Gen Stop 1 (blue) to new #16 - gen stop, normally open.
    Old Gen run (brown) to new #12.
    If it's an Onan, Type 2 should be the ticket, maybe type 1.
  • Is anyone out there good with any of this? I really need help. Customer is waiting to pick up.
  • http://imgur.com/VmkY9Dy
    http://imgur.com/SdEnmiq
    http://imgur.com/D7jBSN7
    http://imgur.com/7QOl36T
    What I wrote in earlier post is what the old harness was labeled as
    http://imgur.com/PtyVxB2
    http://imgur.com/AwcswgA
    Better images of new harness diagram
  • Let me see what I can do, so long as I can upload pictures from my phone we should be okay, give me a minute.
  • You need to start a program here for this to work.
    Draw EACH diagram out one on the top of a page
    The other just beneath it.
    Then take an image and upload it to the site
    Would make all the difference in the world
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Apr 05, 2017
