TCBear
Oct 05, 2023Explorer II
PART #7 OF 8
ANTI-NOISE INSTALLATION TIPS
For each pump listed above you can find Amazon reviews that say “Quiet pump!” AND “Noisy pump!” So I won’t even go there and try to referee all that, it’s subjective and pointless, and much noise comes from the installation and plumbing anyway. All pumps come with rubberized bases to reduce vibration and noise. Their four-screw mounting hole spacing appears fairly consistent amongst brands, generally a 73 mm by 83 mm (2-7/8" by 3-1/4") rectangle (oddly 58 mm x 81 mm for Flojet). The Shurflo #2088 pumps commonly used as OEM have 76 mm x 83 mm hole spacing, but you can reuse those holes by simply tilting the screws a bit while inserting -- the difference is only 3 mm total, or 1.5 mm per screw. Measure your new pump's feet to get an idea of proper screw length and buy new screws to reduce the likelihood of complications. Your installation may differ, but a #8 wood screw 1.25" long is a good starting point, or 1.5" if you insert a mouse pad or similar under the pump feet. You might buy 1", 1.25" and 1.5" #8 wood screws and return what you don't use. Otherwise just use a drill or nail to make new holes if the prior holes don't work; Shurflo recommends lightweight #8 diameter screws (thicker screws actually transfer more noise to the board), and do not overtighten them, which may compress the rubber and therefore increase noise transmission to the plywood or other base. A solid base is best – a lesser, thinner base that sounds like a drum when tapped can transmit noise. Inserting a small patch of carpet, mouse pad or felt pads for furniture legs between the pump’s base and mounting board can help, or perhaps a hardware store has supplemental rubber washers, bushings or such that can help, although all of that may be overkill. In one forum thread an installer ran his new pump, with rubber feet on the plywood, and noted the noise. Then he lifted it up in the air, off the plywood, and the noise did not change. This suggests that noise is much more from piping than from rubberized feet on a new pump, with little need to “improve” manufacturers’ pump mounts.
RV water pumps shouldn't be connected directly to rigid piping since doing so will transmit vibrations, and therefore noise, throughout the plumbing system and RV. It can also invite pipe cracking and joint loosening. Instead you should install at least 12 inches (Lippert says 12" min, Shurflo says 18" min) of flexible hose at both the pump inlet and outlet to absorb that vibration rather than transmit it. If your old flex hose has stiffened, you might replace it. You can even install a pre-made 36 inch long flex hose "silencing kit" at the pump inlet and outlet, with each hose curved into a big, wacky, loose loop (like a water rollercoaster!) if space permits, to help reduce noise, and such hose loops are actually recommended by Flojet. Google "Xylem FloJet 3426 Series Manual - ManualsLib" for an image of the installed loops, or view the photo below. See Shurflo #94-591-01, Camco #20105, and Valterra #P23512PB universal hose silencing kits (see Amazon reviews before considering the RecPro equivalent). Also see Shurflo #411-010-00, 411-020-00 and 411-030-00 for other universal silencing hose options. Or you can use bulk generic hose – see Eastman/EZ-Flo #98628 or by-the-foot EBay options, ½” ID and ¾” OD (inner/outer diameters) of reinforced hose made of vinyl/PVC/polyvinyl chloride, their thickwall ¾” outer diameter helping to prevent hose kinking. Search terms are “1/2 vinyl reinforced tubing,” with tubing the proper term rather than hose. The various “silencing kit” hoses are safe for RV drinking water, but for generic bulk hose look for ANY of "potable/food grade/non-toxic/FDA compliant/NSF51/NSF61." (51 is safe for foods and beverages such as milk and beer, 61 is specific to potable water, but either is sufficient for RV freshwater. Since vinyl MAY impart a taste in water when stored, it’s possible that 61 is unattainable for vinyl flex hose, the taste issue failing the standard even though safe.) Don’t buy standard (non-reinforced) clear vinyl hose rated at 30 psi, but look for reinforced vinyl hose with the polyester white stringy thingies (NOT embedded worms!) rated at 150 psi. For 3/4" OD hose it's best to use hose clamps that max out at 7/8" or 1" diameter such as the Ideal #670040008018, Apollo #IDL16 or Everbilt #6760595. If using larger clamps and tightening them down to 3/4" they have a tendency to compress into ovals with sharp angles, which you'll want to flatten out into a smooth circle with a pair of pliers. Better to just use a properly sized smaller clamp to avoid complications or leaks. Avoid 90 degree elbow fittings close to the pump’s outlet port, although sometimes they’re unavoidable. They cause turbulent water flow and also back pressure, both of which generate noise. Use smooth curves rather than right angle bends where possible.
