TCBear
Oct 17, 2023Explorer II
Image above-right of recommended 36 inch long noise/pulse reduction hose loops as depicted in Flojet owner's manuals. Helpful for any brand or type of RV/boat water pump.
Text says "Note: To help reduce noise and vibration of the pump through the system use flexible lines on the inlet and outlet of the pump as shown above. Be sure to use lines rated to not collapse under pump vacuum." (Shouldn't be an issue with the reinforced thickwall hose previously mentioned.)
