coffebreak's avatar
coffebreak
tire codes, how to read??
bought a used 2008 trailer today and the tires on it are ST/175/80D/13
they look in great shape no checking or wear.
there is a DOT number on the sidewall which reads
DOT 4LJU and than in a circle are the numbers 3606.
can anyone tell me if these are new tires or need replacing?
if they need replacing they are load range C with a capacity of 1310 lbs per tire.
i found a ST/17580R/13 with a load range of D with a capacity of 1610lbs per tire.
if i need 4 tires is it better off to go with the D range for almost the same price and its a radial.
the trailer is 21ft and dry weight is 3400lbs in which we will have about a 1000 lbs in gear.
thanks for the help
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 13, 2026
