I have been running 225/75 r15 tires on my trailer, load range D. Have been considering getting load range E. same size tire, and running at lower air pressure, 60 to 65 like I have with the load r...
Any Load Range tire isn’t able to carry their max weight until inflated to max rated pressure. Is a little reading regarding tires on your menu?
So, laknox, when your tires fail and you truthfully say you intentionally didn’t inflate them correctly to manufacturers specs, will you buy lunch for your lawyer after the courts dismisses your case?
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
