2manytoyz
Jun 20, 2019Explorer II
I need to add the extra wire to my TOAD to charge the Jeep's battery when I'm towing it. The RoadMaster Even Brake system has an onboard air compressor, which continues to draw power each time the brakes are activated.
On our last trip, I got a warning message on the Even Brake monitor, indicating the vehicle's battery voltage was getting low.
Pin 4 is the charge line. Connect that wire to the TOAD's battery, put in an inline fuse at the battery. The Class A will already have a fuse to protect the wiring to the 7 pin connector. But your Honda won't have one it its end if the connector shorts out when disconnected. I never connect anything to a battery without a fuse!
