MEXICOWANDERER
Jul 08, 2017Explorer
Stabbing lead posts with Oldaker test probe points using multiple meters for verification of data. The Borg has 6' x (2) 6 AWG leads and Mueller 100-ampere copper clips. Voltage drop obviously must be present and it averages .21 volts at full rated output @ 14.8 volts. Voltage drop doubles to .46 volt at full rated output. Ampere hour accumulation corroborates the values shown.
To extrapolate theory with real observation when the 3300 amp hour bank needs a crucial recharge I use the 50DN alternator plus the ferroresonant 220 ampere charger. 385+220 amperes, in excess of 600 amperes. 28.8 volts is the goal. Remember I am using 350 mcm cable and there are 4 leads.
Instant Vabs Max is only useful for a minority percentage of the entire charge exercise. The first thirty percent with my FLAs. Amps per volts subsequently is not linear. Reliance on stable Vabs Max with no automatic default is every bit as important, time wise to minimize run-time.
Do the batteries get warm? Yes of course. A 25 degree Delta T (differential) is not unusual.
The Borg was conceptualized for a maximum 200 ampere hour battery bank. To me, realizing greater output from a shoebox size charger was not rational. Being a receptacle connected device thought had to be given toward limitations of available input power.
If there is anything out there that can vie with the Borg's power and versatility (and utility) I am not aware of it. My defective body carries the charger with ease even though it has a 20 gauge steel enclosure.
Since the Lifelines are on standby I am going to substitute a CheapOwatt for the Borg. Set at 13.20 volts.
I may or may not build another Gigawatt and swap them for the original units.
A thermistor influenced Megawatt is a few rungs higher up the ladder. Amphenol mil-sprec gold socket and plug. Armored lead. With the wireless amp hour meter and voltage divider (pot) placed in series with a timer for float the project promises to be interesting.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
