webhannet
Jul 19, 2014Explorer
First things first - get a new water valve for the toilet!
If all the water coming INTO the trailer is off, is your water tank HIGHER than your toilet valve?
Color in the bottom of the toilet only indicates that nothing is comeing from BELOW, and I suspect your nose would know if it was.
It's an interesting question, but I suspect it'll be an easy fix. You might also install a toilet line shut-off (like at home) if you don't have one. Be sure to check that the toilet valve actuator rod or cable isn't somehow pinched causing it to be too short.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
