glorio
Jul 20, 2014Explorer
I have a sprayer on my toilet and it is connected to a vacuum breaker on the rear of the toilet
It is a check valve and maybe something to be look at because it connect to the water supply to the toilet. I also think you should replace the flush valve. Make sure you water heater was not left on
And an outside shower faucets were not left on and feeding hot expanded water in the cold side
And into the toilet.
I know this sounds far fetched but it could happen.
Good luck with your search for a solution.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
