I've replaced my spray hose unit before -- does this just need a new seal or do I need to replace the whole thing? Or will I not know until I dismantle it?
That is just a press fit- it pulls right out. If it is leaking there, and not from the top of that assembly, I would just pull it out, clean it up and put some plumbers grease on it to reinstall. I do not believe the gasket is available except as part of the vacuum breaker kit.
Bumping this up. Can I just buy the seal or do I need to replace the whole thing. I need to get the part before I take it apart and don't know what to get. Thanks....
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
