My Tetford(sp) Aqua Magic which is in a 2002 Wildrness will not hold water. I cleaned the sliding valve but did not fix the problem What can I do for this besides getting a new toilet?
What model Thetford toilet? many have a groove that the slide goes into. Any small piece of debris will cause the slide not to close fully. Thetford makes an angle cleaner. It has about a one inch arm bent 90 degrees to the shaft for cleaning grove. I made my own out of a metal coat hanger. Bent one end 90 degrees. Left hanger about eight inches and bent other end into a handle.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
