BB_TX
Aug 31, 2014Nomad
I have a Sealand toilet. At about 2 yrs it would not hold water. Took it apart, cleaned the rubber seal, lubed it with Pam (per Sealand), put it back together and it held water for several years.
Same problem this year but cleaning did not work. Had to replace the hardened rubber seal.
On mine there is a metal band something like an oversize hose clamp that holds the top half of the toilet to the bottom half. Loosen the band and the top half lifts off. No need to remove the bottom half.
