Gjac
Oct 21, 2017Explorer III
TenOC wrote:I had this same problem with hard water deposits that I had to scrape and clean off. These were brown and very hard. Used a scraper first then steel wool to remove the rest of the buildup. The old seal worked well after the clean up.
I had the same problem. Replaced seal twice still leaked. Then I use some toilet bowl cleaner. The cleaner dissolved the "lime" around the ball. I could see it bubbling around the ball. Now for the past 4 months it work fine
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
