pdlarson's avatar
pdlarson
Tongue Jack Blowing Fuses
Not sure if this belongs in Travel Trailers or Tech but here goes: My electric tongue jack keeps blowing 30 amp fuses. I don't recall this happening for the first year or two I had it but suddenly earlier this year I started having trouble. There is a manual override but it is very difficult to crank. I have a supply of fuses that has helped me out of a jam but I'd be curious to know why this is happening in the first place. I don't see anywhere where it says what size fuse to use, 30A is what it came with new so that is what I have been using. I know that in general the recommendation is to not insert a higher rated fuse and to inspect everything because fuses blowing could be a sign of other trouble. The problem is that I can't seem to find anything wrong. This typically happens if the jack is over-extended in either direction (not on purpose or for a long time but you never know when it will stop until it stops) or when just starting to lift the tongue. Any ideas?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 19, 2025
