wa8yxm
May 11, 2019Explorer III
They talk about waste heat from machenery.. There are many many ways to turn heat into electricity.. You have at least 3 devices that do just that in your RV more than likely.. One in each of the following: Furnace, Water heater, Fridge (Unless you have a residential fridge).
The flame sensor is a Thermocouple. it turns heat into electricity.
Another device: There are a number of companies that make little warmer/coolers. these usually run on 12 volts (Draw around 6 amps) and hold perhaps a six pack of soft drink.. Some are hard sided some soft (one is shaped like a mini fridge about 1/3 cubic foot) Described in this article on Thermoelectric cooling THey also generate electricity if one side is hot and the other cold.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
