Almot's avatar
Almot
Explorer III
Dec 17, 2013
Too many holes in solar panel frame?
My bad. Changed the design of PV mounts after had already drilled holes in the frame. So the panel is a lot lighter now, and plenty of ventilation :)... Big panel, 60x40", 40 lbs. I can see how it flexes when I lift one corner, though it probably would without my holes too. Since it will be tilted, frame strength may become an issue.
One side has 4 holes from 1/4" machine screws, the frame is double-walled here, but very thin aluminum, less than 1/16". Plug them with huge aluminum rivets?
2 other sides have 5 holes after #10 machine screws in single wall - plug with rivets again? And 5 holes after #8 tapping screws in a double wall - those I can just fill with caulk to stop water from getting between the walls.
And a couple of extra water drain holes that I drilled because the original drains were covered with mounting brackets (which brackets I then decided to forgo). Those are oval like the original drain holes, so nothing can be done.
