wa8yxm
Jun 28, 2020Explorer III
MEXICOWANDERER wrote:
Conversion to wireless sound?
BLUETOOTH
I realize a little chip can allow a PC or laptop to broadcast a bluetooth signal.
Does another gizmo exist that will turn an amplified speaker into a wireless speaker? Like a Polk 10" subwoofer?
A whole bunch of them.. You can buy "Blue Tooth Receivers" starting at around 15 bucks some do not even require the speakers be amplified.
A common Raspberry Pi. Any model with BT or a BT adapter can also be used (Belana Etcher is the program I use to burn Raspberen (the Linux Operating system for the pi's) to the memory card. They advertise a downloadable set of instructions for doing the job, I've not done it because I've no need to do it).
A Pi-Zero-W is 10 bucks at Micro Center .plus 10 bucks for the memory plus the BT adapter So the ones I found with a quick search are possily less expensive (The Belana option allows multiple pi's to receive the same signal but Well. I'm still learning Linux for other reasons and if you don't know it... )
I searched on blue tooth receiver to find the 15 dollar and up units.
I have one. Don't use it but I have one
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 26, 2026
