- wclogger1ExplorerBest method I have found is using a small pump that screws onto the top of a oil bottle with a flexible plastic tube for delivery. It is designed for pumping oil into outboard motor legs but works great for a lot of other things. You can pump in or out. You can get them at most hardware & automotive stores.
Bob - Grey_MountainExplorerThanks for all the replies. My RV fixer tried a fix before we left - simply lubed the jack. He said at times, that will do the trick. That worked for several extensions and retractions, but finally it started leaking again. I fill the reservoir with a turkey baster - but it's still difficult to get to even to do that. After this stop, jacks will only go down one more time before we get home and get the RV into the shop. They are Power Gear jacks,and I check the level with the jacks fully retracted.
GM - southwindtrailExplorerI just had mine fixed I filled mine up for a year or more and it was fine on a 99 Southwind
- John_JoeyExplorerSimple fix, go to the dollar store and buy a turkey baster. Suck out the excess. Keep an eye on the level for the rest of your trip. Fix the leak when you get home.
Don't over think it, and enjoy the rest of your trip. - wa8yxmExplorer IIIIs it possible to put in too much: YES
Does the excess just leak out: Has for me so far. so YES.
Other than a bit of a mess, depending on where the tank is, Don't worry about it.
Now more:
I full time. This means that in the cooler season where temps are down below 40F (IE: Today) I have to add fluid because the fluid "Shrinks" when cold faster than the tank and the idiot alarm dings.
But come August when it's 101 in the shade. there is now too much in the tank and on the ground it goes. Not a good design. - Old-BiscuitExplorer III
RJsfishin wrote:
Jacks are one way cylinders, so must be fully retracted. Hydraulic slides are 2 way cylinders, so probably don't matter if they are in or out when filling.
Jacks should be retracted before filling/topping off reservoir.
My hydraulic slides are the same.....all slides retracted before checking fluid level and filling/topping off.
If I topped off reservoir with slides extended I would be cleaning all of the hydraulic fluid I put in to top off out of compartment.
Don't assume......check manual or with mfg. before topping off. - wolfe10ExplorerDepends on the brand/model of jacks.
Tell us what you have, and we can be of more assistance.
Some have a dipstick, some you fill to a mark on the fill hole, some you extend one jack 6" and fill until the light/buzzer goes out. VERY different. - RJsfishinExplorerJacks are one way cylinders, so must be fully retracted. Hydraulic slides are 2 way cylinders, so probably don't matter if they are in or out when filling.
- MrWizardModeratorcheck fluid with jacks fully retracted
if they need fluid, add but do not over fill
if one jack leaks, it needs new seals - past-MIdirectorExplorerDepending on make some will vent excessive fluid out on the ground or inside a compartment under the reservoir. Manufactures recommend to service the reservoir with jacks up and not to overfill.
Having RV issues? Connect with others who have been in your shoes.24,353 PostsLatest Activity: Jan 23, 2026
