Captain_Ron's avatar
Captain_Ron
Hydraulic Fluid Reservoir Location
I have a 2006 National RV SeaBreeze model 1341. I cannot find the hydraulic reservoir for the jacks. The jacks just stopped working. Won't go down or make any noise that I can hear. I want to check the fluid, but can't find the reservoir to check and fill. Please help. The lights on the panel work and I have checked the breaker. Thanks
  • On my 2004 Seabreez the tank is right behind the grill, drivers side. You can see it looking through the grill. Double check that your parking brake is "SET", & ignition switch "ON".. I get the panel light LIT but jacks donnt work if the ignition is off
  • in my 2007 Ford Winnebago it was outside about under the divers seat - had to open the slide to get to it.
