Jspitz128's avatar
Jspitz128
Explorer II
May 11, 2025
Solved
Trail-lite 211 b+ transfer switch location
I have a 2003 trail lite r-vision 211 motorhome that I just purchased.  The generator wouldn’t start so I had a new carb put on and now it runs.  When the mechanic tested the generator he turned on t...
  • Jspitz128's avatar
    Jspitz128
    May 12, 2025
    Thanks to everyone that replied!
     I found the transfer switch and have bypassed it by putting a 30 amp female end plug in coming from the generator into the shore power storage area.
     Now to use the generator I just have to plug in the shore power to that plug in when I want to use the generator.  This is how many other RVs are set up that I have seen and I prefer it that way because of simplicity and less electronics to have to rely on.
    The transfer switch was on top of the power converter.  I couldn’t see this until I removed the drawers above it.  I never did that until your suggestions because I could see the back of the power converter from under the sink but the switch was hidden from the back.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
