Jspitz128's avatar
Jspitz128
Explorer II
May 11, 2025
Solved
Trail-lite 211 b+ transfer switch location
I have a 2003 trail lite r-vision 211 motorhome that I just purchased.  The generator wouldn’t start so I had a new carb put on and now it runs.  When the mechanic tested the generator he turned on t...
  • Jspitz128's avatar
    Jspitz128
    May 12, 2025
    Thanks to everyone that replied!
     I found the transfer switch and have bypassed it by putting a 30 amp female end plug in coming from the generator into the shore power storage area.
     Now to use the generator I just have to plug in the shore power to that plug in when I want to use the generator.  This is how many other RVs are set up that I have seen and I prefer it that way because of simplicity and less electronics to have to rely on.
    The transfer switch was on top of the power converter.  I couldn’t see this until I removed the drawers above it.  I never did that until your suggestions because I could see the back of the power converter from under the sink but the switch was hidden from the back.
