- pianotunaNomad IIIHi Korbe,
What does the volt meter say 24 hours after you have arrived home? (assuming you do not plug in) - korbeExplorer
pianotuna wrote:
Hi korbe,
How did you determine the 50%? and the 90%?korbe wrote:
here is what I experienced. My 2 6-volt batteries were at about 50% discharge when we took off for home. After 7 hours of driving, my batteries went up to about 90%.
My crude process was my volt meter. About 12.10v to 12.6v - after I let it sit awhile. ekirkland wrote:
Roof has a lot of advantages. Including charging while driving.smkettner wrote:
The charge may start a bit higher but 10 amps is about the most you will get.
The best solution IMO is 200+ watts of solar.
Is there a portable solar charging system you can plug in and set outside on the ground instead of having to permanently mount it on the roof?
https://www.solarblvd.com/index.php?cPath=1_272
Also check amazon ebay etc- ekirklandExplorerSome of the replies went right over my head. It sounds like some are saying a separate heavy gage charging wire with battery isolator is the way to go and some saying that's not such a good idea. What is a mechanically and electrically challenged person to do? I guess I have the options of parallel charging line with isolator vs. solar vs. generator. About the most I intend to dry camp is 3-5 days and then hit a campground with power to recharge on our next trip to Utah. I would imagine the batteries (2 ea. 24's) would be pretty depleted in that 3-5 day period. My present Jayco camper is new and we have not done any dry camping yet; only powered camping. With our previous Casita, we could do maybe 4 days with very frugal power usage on one battery. I'm trying to decide my best (maybe cheapest) means to extend battery power. Thanks for all the help.
- pianotunaNomad IIIYes, but with panel prices as low as $0.28 per watt why not do a permanent installation.
ekirkland wrote:
Is there a portable solar charging system you can plug in and set outside on the ground instead of having to permanently mount it on the roof? - pianotunaNomad IIIHi korbe,
here is what I experienced. My 2 6-volt batteries were at about 50% discharge when we took off for home. After 7 hours of driving, my batteries went up to about 90%. - ekirklandExplorer
Is there a portable solar charging system you can plug in and set outside on the ground instead of having to permanently mount it on the roof? - The charge may start a bit higher but 10 amps is about the most you will get.
The best solution IMO is 200+ watts of solar. - korbeExplorerWithout getting into the nuts and bolts of wires and diodes and the like, here is what I experienced. My 2 6-volt batteries were at about 50% discharge when we took off for home. After 7 hours of driving, my batteries went up to about 90%.
- tvman44ExplorerA long long time to get fully charged.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
