fitznj
Jun 29, 2016Explorer
TRy backing off the gain - mine are grabby at slow speed if the gain is too high.
Last year I had similar issues which drove me nuts. As others have pointed the wiring is usually daisy chained from one wheel to another. I removed the wiring and had a dedicated wire to each separate wheel. The braking is now much better and even.
I did notice a loose ground - so I suspect that this may have been causing some issues with the "jerky" brakes.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
