MFL
Apr 02, 2019Nomad II
sign man wrote:
found it 2830lbs its only an extra 15lbs of air pressure. should be fine?
The E-rated will work, just be sure the valve stems are rated for 80 psi also. Air to full pressure to get the advantage of the heavier tire.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
