CALandLIN
Apr 09, 2019Explorer
sign man wrote:
When going from d rated to e rated Should the e rated tires always be inflated to the maximum pressure regardless of how much weight there is?
Anything above vehicle manufacturer recommended 65 PSI is optional. But, you waste your money for additional load capacity reserves if you don't use some of it.
Maximum inflation for Original Equipment trailer tires is a normal recommendation. It's not a requirement for higher load capacity replacements.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
