Not quite an RV question, but--I'm volunteering at a Fl state park. We have decorated a tram to use as a float in a local parade. When checking the turn signal & brake lights on the tram I am having a...
90% of trailer light issues turn out to be bad grounds. Ground each light fixture to the trailer with a separate wire; (you can do this temporarily using a wire with crocodile clips to verify)
Trailer lights usually use the nuts holding the light as a ground - which corrode over time.
Also check the white wire is really grounding - use a multimeter to verify.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
