Not quite an RV question, but--I'm volunteering at a Fl state park. We have decorated a tram to use as a float in a local parade. When checking the turn signal & brake lights on the tram I am having a...
Checked all the wiring and could not find anything wrong. Found a site that gave some troubleshooting info. Whoever first wired it hooked the ground wire to the aluminum housing on the part that goes over the ball. Site stated that it shouldn't be that way, it needs to be on the frame instead. Moved it to the frame and it works very well. Very bright also.
Thanks to all for the helpful hints!!!!!!!!!!!!!!!!! DICK
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
