Broc7422's avatar
Broc7422
Trailer wiring/light problem
Hello when I turn on my running lights on the brake lights and turn signals don't work. But when the running lights are off they work just fine just a little dim. And the running lights are bright. I don't know if I just need to switch a wire or its something more. Help me out please.
Thanks
  • If a trailer light fails my first action is to give the connector a squirt of contact cleaner.
  • The quick and dirty test for bad ground is to take connect a jumper cable from the frame of your truck to the trailer frame and see if the problem goes away.
  • I have a 2010 f150 XLT. I'll test the trailer brake testand check the grounds.
    Thanks
  • I would lean on bad ground, but there could be other possible causes. But, usually bad ground will make some other lamp light dimly, because the current is back feeding to find a way to find a continuous circuit.
  • ALL LIGHTS MALFUNCTIONING means an error common to all.
    That would be CHASSIS NEGATIVE.
    Have a 2nd person man the brake controller when you're doing your testing. If the lights act screwy and then go out altogether when trailer brakes are activated you can take BAD CHASSIS NEGATIVE to the bank.
    Negative wire from tow vehicle frame to socket. Many many bad connections to truck frame.
    Negative wire within socket and or plug
    Negative wire from trailer plug to trailer chassis
  • Welcome to the forum. Although your description points to a bad ground, you've given us little to work with. What vehicle is this? What has been done to it recently?
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 21, 2026
