Chinolbz's avatar
Chinolbz
Transfer Switch Install
I thought I understood how this works but maybe I could use your help. It looks like all power sources must be disconnected from the converter/charger and rewired to the transfer switch. I get the shore power/generator wires. Out to the inverter, OK. Do I seperate the sections, i.e make the converter and charger their own parts and wire them to different terminals of the transfer switch? Not that tough but it will certainly take some planing. Thanks Chino
  • Shore power wiring goes to one 'input' side of transfer switch
    Generator power wiring goes to other 'input' side of transfer switch
    Main Power wiring comes from 'output' side of transfer switch to the Main AC Power Distribution Panel.
    Converter/charger is feed AC power from main AC panel and provides DC power to DC Distribution Panel/Battery Charge
    Inverter is feed DC power from battery and provides AC power to either dedicated AC circuits or main AC panel (depends on size of battery bank and size of inverter)
    Hopefully you have help or at least someone to check system prior to energizing.
  • The transfer switch normally works to separate the generator and shore power to the power panel. Not sure how your coach is set up, but as you referred to safety, you need to be careful that the power from either source doesn't bypass the proprietary that's being used at any one time. Do you currently have an automatic transfer switch, or manual?
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Jan 03, 2026
