WE-C-USA's avatar
WE-C-USA
Transfer Switch WFCO T-57 ??
I just installed a T-57. Incoming 50 amp shore power thru surge protector to the T-57 transfer switch. Black to L1- Red to L-2 on the T-57. Works great when on shore power.
On the generator side , white to neutral, gr to gr, black (HOT) lead to L2, since that's the only side of panel I want to power.
Doesn't work. Won't transfer. The only way I can get it to work is a jumper on the gen side between L1 & L2.
Does L1 have to be powered first before the switch will work?
They state it's either 30-50 amp, but 30 amp would only use one side.
  • You may be correct. I was describing the markings on the T57 transfer switch. And it is Generator L1-L2-N-AUX. Sorry for the confusion.
  • Bobbo's avatar
    Bobbo
    Explorer III
    WE-C-USA wrote:
    I got everything the way I want. Moved the hot gen/inverter wire from L2 to L1. Transfer switch worked without jumper. I then reversed the L1 & L2 ( Black-Red) to the control panel (output) side.
    How I only power the things I want too.
    The main reason I don't want to power one side, it has- Water Heater-AC-Convertor & some outlets, things that are not used while using the 2000w inverter. I wanted the converter off while using the inverter/charger/generator. I use a Honda 2000 mainly to recharge batteries.
    WE-C-USA wrote:
    Bobbo wrote:
    I can't help wondering what the downside is for powering both sides. You don't have to USE the other side.
    Yes I could power both sides. Then while using the inverter, I'd have to either--turn the Convertor circuit breaker off or install a relay. You don't want to run both at the same time.
    This is the first mention of an inverter. You kept saying "generator." That particular detail would have aided those trying to help.
  • I got everything the way I want. Moved the hot gen/inverter wire from L2 to L1. Transfer switch worked without jumper. I then reversed the L1 & L2 ( Black-Red) to the control panel (output) side.
  • Bobbo's avatar
    Bobbo
    Explorer III
  • Thanks for the replies. I really only need one side powered while boondocking. TV, coffee pot & maybe Microwave. I'll try using L1 only on the Generator side and see what happens.
  • The switch coil is just 120v and comes off L1. Besides you want all of your RV powered right? It is proper to bond L1 & L2 at the transfer switch on the generator side so everything works
  • DrewE's avatar
    DrewE
    Explorer III
    It would appear that it is so. Swap L1 and L2 on the output and connect the generator to L1 and you should be good to go. (I must admit I do not really understand why you would not want to power both legs from the generator, rather than leaving one dead, but I suppose you have your reasons.)
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
