MEXICOWANDERER's avatar
Sep 23, 2015
Transient Voltage Spike Protection Home Made Device
I'm stubborn. When I found out how stupidly expensive adequate "Surge Protectors" cost, I hit the roof. Screw that. I ordered the components.
Designed for 180 volt peak-to-peak protection ((the standard down here is 127vac 60Hz.)
20 mm Metal Oxide Varistors
10 mm Metal Oxide Varistors (10 volts higher rating)
Transient Voltage Surge Protection bi-directional diodes 4ns reaction time
Gas Discharge Tube devices
L1-L0
L1-Earth Ground
LO-Earth Ground
(8) MOVS
(4) TVS
(2) GDT
I'll see about sending some images to NinerBikes.
If you can do basic soldering, you can do your own and end up with genuine protection and not a vastly overpriced fraud.
BTW: A fully functional grounded isolation transformer is 100,000 times better than my gizmo.
  • Perhaps I'm not so smart - BUT....I bought a progressive, installed it myself and it has saved every electrical thing in the rig - TWICE!!
    I consider it an EXCELLENT investment!!
  • Ava wrote:
    My Progessive unit also protects the electric units from low voltage which will burn out any appliance if left on with low voltage. So I have high and low and miswired connection protection. Some things are worth the cost.
    What he said.. :)
  • My Progessive unit also protects the electric units from low voltage which will burn out any appliance if left on with low voltage. So I have high and low and miswired connection protection. Some things are worth the cost.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 19, 2025
