BobsYourUncle
Jun 20, 2021Nomad
draboo wrote:
The flange on the tank is glued in, so it cannot be moved.
Are you sure it is glued in?
One of my first posts on this forum, if not my very first one, was asking how the toilet flange came off. I think some said it was glued in, but others told me it was threaded.
On mine I think there were a few screws into the floor. After taking the screws out, I used a blunt drift punch and a hammer, rotated the flange counter clockwise out of the tank. It came out very easily when I knew how.
I suggest you try that, and replace the flange with a new one, checking the size and clearances etc to ensure you get proper compression on the new gasket.
Also check the bottom of the toilet for any irregularities. Put a small straightedge across the outlet, moving it side to side and rotating it to make sure it is perfectly even right across and not warped.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
