stevenal
Jun 20, 2021Nomad III
I avoid going much past 2/3, I don't want sudden braking to cause a spill.
I recently changed the flush valve on my Thetford. The kit came with a new gasket, which I used. I found the gasket easily moved off center, and it took several tries to get it right. I had to open the valve and look down the throat to see if the gasket was even. You should be able to see the extent of gasket compression in a similar manner.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
