azrving
Mar 18, 2017Explorer
Some volt meters use a battery inside them and will give wacky readings if it's low.
From there you should see panel voltage at the junction strip and the same voltage at the controller.
If you remove the panel wires from the junction box and use an amp meter between POS and negative you will read isc amperage short circuit. Just like checking open circuit Voltage it will depend on sunlight
