pianotuna
Jun 12, 2018Nomad III
Hi,
There is no mention of this being a hybrid unit. So how are you combining power from the generator and the inverter?
Or do you have the generator powering only the converter?
NRALIFR wrote:
The brand name on the inverter is Novopal. The exact inverter I bought on Amazon is no longer available, but it’s physically and spec’s are identical to this one. I suspect it’s made in the same Chinese plant.
Edecoa 1500 PSW Inverter
The only difference on mine is the remote switch is a simple mechanical on/off switch, where this one has an LCD panel which looks nice but does draw a little power. I haven’t looked at the output waveform with a scope, but everything with digital controls I’ve plugged into it has run fine, and I’ve verified that the idle current draw is .5 amp. It’s very quiet, the fans are on/off and speed controlled depending on the cooling needs. With light use, the fans hardly run at all. When running at highest speed they aren’t annoying screamers like some inverters I’ve had.
I’ve been using it for about a year.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
