burningman
Jun 14, 2018Explorer II
If you want to run the micro for ten minutes straight, you’re gonna need at least four batteries, but if you’re going to run it for a minute or two at a time and have solar topping the batteries off, I think two will get you by. Mount the inverter next to the batteries so your cables are only maybe two feet long and use HUGE cable.
The size of cable and how short it needs to be is the most misunderstood thing about using inverters.
I’ve got 2-gauge on mine which is too small, but I have them tripled up, three positive cables and three negatives, and very short. Any less and I can’t get full power... or even close to it.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
