solismaris
Jun 09, 2014Explorer
enblethen wrote:
You may want to build a relay setup. Run large power wire to main contact, contact output to trailer lights. Use the output from the module to operate the individual functions. Would take two relays, one for each turn signal/brake light function.
I'll probably try replacing the trailer bulbs with leds first; I think that may solve the problem. If I still have problems I'll consider more complex fixes.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
