wa8yxm
May 31, 2013Explorer III
exeter_acres wrote:
is there a recommended and Easy way to drain them so I don't have to remove a couple fuses every time I put the RV away?
What happens if you turn on one of those Incandescent lamps that do not work with the battery disconnected?
Oh, by the way, that is the answer to your question, THEY are the recommended way to discharge the cap's on the converter, May take up to a minute to finish the job depending on the size of the caps.
Each farad of cap is one amp-second.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
