talotto
Jan 22, 2016Explorer
One clarification is that you don't have "electric heat" in the normal sense, that is, there are no electric heating elements in the unit. So, it will work when you run out of propane, but only if the outside temperature is high enough for the heat pump to pull heat out - about 35-40 degrees or higher. Below that, the heat pump's efficiency essentially drops to almost negligible
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
