dougrainer
Jan 22, 2016Nomad
The above answer presumes you have RVP(Coleman) Heat Pumps. Here is a more detailed explanation. If you are out of LP, it will take a lot longer for the HP to heat the RV to temp. Doug
http://old.rvcomfort.com/rvp/pdf_documents/t_stat_electric_heat_function.pdf
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
