Alan_Hepburn
Aug 11, 2013Explorer
JohnDoe wrote:
Hi I got a TST system and having trouble getting the tire pressure reading on the moniter,sometimes their there then their not but the tire icon is still blinking,Any ideas.THX>
_______________________________________________________________________
All I get is the blinking tires, should I be getting tire pressure on my screen??is there a way to get it?
I just installed mine this weekend. My first thought is: did you properly identify each sensor before you installed it, according to the directions? With all the sensors several feet away from the monitor you need to bring each sensor, in turn, close to the monitor and press a button to allow the monitor to correctly identify that sensor. It will show a 6 digit ID number when it is identified. Once that is done, you install each sensor in the correct position. When I installed each of my sensors I had the monitor up on the dash and by the time I screwed the sensor onto the stem and tightened the set screw (the so-called "locking device"), and got back to the dash it was displaying the pressure and temperature of that tire.
I do notice that when I power up the monitor it can take up to 1/2 hour for it to recognize all the sensors.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
