joelyn's avatar
joelyn
TT AXLES?????
HAVE A 04 TT TANDEM axles that are the torsion type of axles... well the rubber has worn out of them and now the tt dropped so low that the tires are rubbing through the wheel wells...
anyone know if these axles somehow can be repacked or the rubber replaced to lift the tt up again or do the axles have to be replaced?
thanks, hope there is some good news....
  • The rubbers can not be replaced. New torsion axles, depending on capacity, run about $350 +/-.
    Lots of info at Dexter axle to determine what you need based on capacity, start angle, bump clearance, etc.
    Go Dexter.....stay away from Lippert.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
