myredracer's avatar
myredracer
Explorer II
Jun 26, 2019
TT brakes not working right - new truck & new wiring
Just rewired all the brake wiring in our TT to all #12 right up to the junction box in the A-frame. Recently installed the Prodigy P3 brake controller out of our old F250 in our "new" 2012 GMC Sierra 2500HD.
Went for a test drive today and the TT brakes just aren't working right. When I pull the manual lever, the TT barely slows down. I jacked up all the wheels and pulled the breakaway pin. Brakes all work, but they're not clamped as tight as I thought they ought to be. Should it be possible to wiggle the wheels at all?
I checked the output at the b/c with a voltmeter and am getting around 12 volts output with brake pedal depressed. Can also measure the same voltage at the 7-pin connector with pedal depressed. The thing that doesn't make sense is that when I go through the troubleshooting menu on the b/c, it says the output voltage is zero and current is about 0.4 amps or less. Is this because the truck isn't moving? but how can I be measuring the voltage on the output wire?
Is there perhaps a ground issue somewhere or maybe bad splice in the junction box in the A-frame or dirty connection in the 7-pin connector? Tail lights, turn signals & running lights on the back of the TT work fine.
The brake controller has been working fine up to now.
Off to check the connections in the junction box and the ground to the frame...
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
