Snowman9000's avatar
Snowman9000
Turnigy meter question
When a Turnigy is used to monitor charging, the charging source is the source side, and the battery is on the load side. If the charging source is off, will the meter show the battery voltage? It doesn't seem so from what I see of it.
There is an aux power input. If that was powered up, would it then register batt voltage in the above scenario?
Thanks.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
